hi guys. I am stuck for once and usually by just using the search function i get the answers i need but missing this one. I would like to assign a permanent action to a hot cue. In this instance i would like to assign hot cue 8 to be the 'load point'. so when i cue hot cue 8 in a song it automatically becomes the load point and i don't have to change it in the POI editor from hot cue to load point for each and every song. Tried a few scripts in the pad editor but to no success. Any help wil be appreciated thx guys
geposted Fri 07 Aug 20 @ 1:29 pm
I think VDJ doesn't have a command for POI editing. I can't find a command myself and i vaguely remember someone in another thread also saying that there is none.
geposted Fri 07 Aug 20 @ 4:59 pm
For your example, you you can use cue 1 as load point instead.
And simply set autoCue in settings to "first cue" ...
geposted Fri 07 Aug 20 @ 6:11 pm
Thx guys the auto cue helps will try and wangle something
geposted Fri 07 Aug 20 @ 10:58 pm
