Topic: Virtual DJ Screen- Too Small to use on Mac
Hi all. Recently I used the yellow button on top left of Virtual DJ software in order to resize the screen. In doing so this has led the icon to appear so small that I cannot press on the green button to fill the screen again. The Virtual DJ softward is about the size of a folder on a home screen!
I have tried to use the cursor to drag the edges bigger with no luck! Any advice on how to resize it !!!
Cheers,
KT
geposted Fri 07 Aug 20 @ 2:31 pm
Should be able to resize (dragging) from bottom right.
Hey there, so the icon is so small that the cursor cannot recognise it to resize it. Its so frustrating and cannot work out how to fix the glitch
Drag bottom right corner to size it up again. (and this new size will also be remembered).
Alternatively, you can rename settings.xml in /documents/virtualdj/ to start fresh with default size
Having the same issue can’t grab corners to resize is there a keyboard shortcut to resize the app
do it thru task manager
I had the same problem this morning and couldn’t figure out what I did wrong. However, after reading the post here, I was able to grab the lower right corner and resize it. Thanks for the info.
Any info here, having the same issue on mac, so small cannot drag to expand
user22925709 wrote :
Any info here
Yes, in the previous posts.
I have the same issue on MacBook Pro 16 2019/ Pro infinity . I cannot grab the bottom right to drag , the Virtual DJ window is now so small it has no response to the cursor . when I close and reopen the programme it go's back to the same size 5mm ...so I pitty anyone who has this happen on a Saturday night . as far as I can see the only option is to restore to previous time .
2-3 solutions above
