Hello,
i was just wondering if you could set up a DVS system with an udio interface. I have the behringer U-phoria UMC404HD that allows me to interact with different DAWS, like cakewalk. I keep messing with the settings for the 2 timecard option and timecode vinyl but nothing seems to work. I am able to see the audio interface in the settings options but it does not show up as its individual card.
Thank you
Ahtovin
Thank you
Ahtovin
geposted Sat 08 Aug 20 @ 4:52 am
I dont think that will work. You'll need a 4 in/4 out sound card that allows you to connect your turntables or CDJ's. Also, since you have a Home License, you either wont be able to use DVS or have limited functionality until you upgrade to a pro license:
https://virtualdj.com/products/virtualdj/price.html#comparison
geposted Mon 10 Aug 20 @ 12:25 pm
