Topic: Could someone explain one thing?
i've seen that video
https://www.youtube.com/watch?v=usCG4tZ6I8o&t=57s
The man there use recordbox. How to do the same stuff in VDJ? There is no "trans" effect and no "beatloop" tab in Vdj. I've tried to install "trans" plugin from this forum, but seems it doesnt work at all. Thank you
geposted Tue 11 Aug 20 @ 5:59 pm
use "cut" same thing or any gate vst plugin
geposted Tue 11 Aug 20 @ 10:47 pm
I was trying to use "cut" effect, it sounds the same while scratch sample just playing, but it breaks rythm when i start to move jog. And where can i find "gate vst plugin"? Was trying to find any "trasform" vst, but no luck(
geposted Thu 17 Sep 20 @ 7:50 am
geposted Thu 17 Sep 20 @ 9:36 am
You can use the Cut Plugin, but you have to change the sample option "Drop" from from "Pitched" to "Flat"
geposted Thu 17 Sep 20 @ 6:15 pm
Sorry, dont understand, why "sample"? I use 2 decks, deck one for song, deck 2 for scratch samples, and was trying to use cut effect for deck 2, but it does't work like trans effect in recorbox, because when i start to move jog, it breaks the rytm. And i don't use sampler for it at all
geposted Thu 17 Sep 20 @ 8:40 pm
Because the sample editor has the function what you want. After this you can load the sample into deck 2 and use it with the cut effect. It works like in the video. Cou can also download and try ChopCut Audio FX.
geposted Thu 17 Sep 20 @ 8:52 pm
Hmmm, i've tried but it does't work like in video. In recordbox i can move jog any way i want, but tempo of sample and "trans" effect doesn't break, but in VDj, after i load sample from sampler (by the way drop "flat" set by default, so actually i haven't changed anything) to deck and added cut effect - when i start moving a jog, tempo immediately changing - it depends on speed i moving a jog. May be i missed something?
geposted Thu 17 Sep 20 @ 9:28 pm
