Topic: crashes got worse!!
thekazPRO InfinityMember since 2009
Using the most recently updated version last saturday, Program kept randomly shutting down and re launching. after the 4th or 5th crash (during a wedding dance), I switched to a backup computer and "downgraded" to VDJ 2018 and had no more issues.
Running a 2012 Macbook Pro, 16 gig ram
500gb SSD
2TB internal drive (in optical bay)
4TB external
Pioneer DDJ SX2 all firmware updated
Oh yeah, when I go to math engine in settings and change it to off to disable stems completely, My CPU is nearly maxed out like it's still computing the stems!
I've got a new MBP ordered, but I'm scared to use the new version in a public performance!
geposted Wed 12 Aug 20 @ 1:11 am
What do you have the precomputeStems option set to?
It looks like the crashes might have happened when saving the precomputed stems, so perhaps you had it set to Always Create.
geposted Wed 12 Aug 20 @ 4:13 am
it was set on always create, what should it be on for a mid 2012 macbook pro? I'm honestly scared to trust it in public and have a copy of build 5874 that I was planning on using tomorrow
geposted Sat 22 Aug 20 @ 3:39 am
