Topic: VU Meter Master/PFL Script
Hello all
I currently own the Numark Mixtrack Pro 3 (Soon to be owning the Pro Fx) controller. And ive realized that in serato if you are playing a song out of the house speakers and you are cueing another song the VU meters would change in regards to what is happening . for example Deck 1 could be live to the audience so the Left VU would show the master output and deck 2 is the one I'm cueing so the right VU would be showing the PFL/Channel Level for that deck . (Hopefully ive explained this clearly, if you have used serato with this controller you will know what I'm talking about)
I am just wondering if there is a script or if anyone knows a script so i can set my VU meters to do the same thing as serato would do . it's not a deal breaker if the software can't do that but if it's available and can be done then id like to make use of it
Thanks
geposted Wed 26 Aug 20 @ 6:16 pm
Change your mapper like this:
<map value="VU_METER_L" action="deck 1 pfl ? deck 1 get_level : deck 2 pfl ? get_vu_meter &apos;master&apos; : get_vu_meter_left &apos;master&apos;" />
<map value="VU_METER_R" action="deck 2 pfl ? deck 2 get_level : deck 1 pfl ? get_vu_meter &apos;master&apos; : get_vu_meter_right &apos;master&apos;" />
<map value="VU_METER_L" action="deck 1 pfl ? deck 1 get_level : deck 2 pfl ? get_vu_meter 'master' : get_vu_meter_left 'master'" />
<map value="VU_METER_R" action="deck 2 pfl ? deck 2 get_level : deck 1 pfl ? get_vu_meter 'master' : get_vu_meter_right 'master'" />
hello
i have tried to copy and paste it into the mapper as stated but the VU meters on the controller just turn off and don't do anything
