Hi,
I'm using a MacBook.
And my mp3 files are free, so not blocked by any iTunes licence.
From Apple Music , I've created several playlists to manage my music.
I can see my musics in VirtualDJ under : Local Music / iTunes / Music /
I can only see the 2 following playlists :
Recently Added
Top 25 Most Played
Why can't I see the other playlists ?
Is it possible to import the playlists I've created with Apple Music into Virtual DJ ?
I'd like to see my playlists in VirtualDJ
Thanks
Recently Added
Top 25 Most Played
Thanks
geposted Sat 29 Aug 20 @ 4:21 pm
So here is the trick (at least what I found). Your recently added etc are likely there because you bought them on that MAc. Go through your iTunes library and make sure you download (the cloud) all the songs you want to your Mac then when you launch VDJ again they will likely reconcile, or you can manually reconcile but right clicking Local Music.
geposted Sat 29 Aug 20 @ 6:05 pm
Hi,
Thanks for your reply.
No I did not buy them with iTunes.
I restarted VDJ and the playlists are still not showing. They have not been reconciled. :-(
Is there a way to import them ? or to find the playlist in a folder maybe ?
geposted Sun 30 Aug 20 @ 5:02 pm
