Hello,
After upgrading to the v8.5-64 b6106 version on my PC, I've got a bug : when I edit a file tag, then click ok, VDJ and my computer are freezing.
Is anybody else have this problem ?
This bug is not appearing on my MAC with the same version.
Cheers
Cheers
geposted Thu 17 Sep 20 @ 5:16 am
When I rename a tag ,it starts checking the history folders and checking default.once this start ,it could take over 2 hours,or it becomes unresponsive and freezes up
geposted Fri 18 Sep 20 @ 11:00 am
It also freeze when importing a backup database.
geposted Fri 18 Sep 20 @ 12:01 pm
no issues here editing tags on windows of a mp3 file
what type of file are you editing the tags for?
is it possible you have a corrupted file? or no write permissions to the folder where the file is stored?
geposted Fri 18 Sep 20 @ 12:14 pm
Alles okay bei mir!
Gruß
Juergen
Gruß
Juergen
geposted Fri 18 Sep 20 @ 12:25 pm
They are mp3 on an external hard drive exfat (so rw for all, no ntfs to share with a Mac).
It was working with the previous version.
geposted Fri 18 Sep 20 @ 7:24 pm
Resolved : VDJ must be launched in admin mode...
geposted Fri 18 Sep 20 @ 7:31 pm
right so it was a permissions problem if you needed administrator rights
geposted Fri 18 Sep 20 @ 11:34 pm
And it would be better to fix the permissions on the drive then instead of running vdj as administrator
geposted Sat 19 Sep 20 @ 6:58 am
Exfat is rw for all...
It was working fine on the previous version without being root...
I also have met some crash when modifying options in the configuration menu.
I will use my Mac version until the next update.
It is certainly a weird bug in Windows system (as always)...
geposted Sat 19 Sep 20 @ 4:35 pm
I've just uninstall and reinstall the application from scratch. It seems to fix all my problems.
It also works without being an admin.
Cheers
Cheers
geposted Sun 20 Sep 20 @ 8:49 am
Finally, it crashs the same way after playing some times :(
geposted Sun 20 Sep 20 @ 11:35 am
It appears your crash might be related to the CoverFlow, so you might want to try to disable that and see if it makes a difference.
geposted Sun 20 Sep 20 @ 1:21 pm
Hello,
Je suis sur PC Lenovo ThinkPad intel core i3 2.35Ghz, 8GO DDR3, SSD 480Go
Depuis la nouvelle mise à jour effectuée ce matin Virtual DJ à planter 2 fois en plein mix en moins d'une heure ! Heureusement c'était pendant des entrainements mais j'ai un mariage dans 15 jours et j'avoue que je suis un peu inquiet... Il me semble que c'est arrivé lors du chargement d'une platine pendant qu'un autre titre était joué. à suivre...
Hello,
I have got PC Lenovo ThinkPad intel core i3 2.35Ghz, 8GB DDR3, 480GB SSD
Since the new update made this morning Virtual DJ to crash twice in full mix in less than an hour! Fortunately it was during training but I have a wedding in 15 days and I am a little worried ... It seems to me that it happened when loading a deck while another title was played. To be continued...
Hello,
geposted Sun 20 Sep 20 @ 3:05 pm
I just found a solution to this crashing problem.
This is a GPU bug (in my case). It seems that VDJ is having problems with cards like AMD Redeon 550X.
So I force the program to use my Intel UHD 620.
The cure : go to the options, then do a search on "gpu", then cross low power instead of default or high power.
Hoping that it helps...
Cheers
Cheers
geposted Wed 30 Sep 20 @ 6:58 am
Sorry, it works 2 hours, then freeze again also while changing or resizing a field on the file interface.
geposted Wed 30 Sep 20 @ 2:40 pm
After testing hours and hours on PC and Mac witch the software works with charm...
It seems that this crashing bug is becoming only when pushing the PC view in full screen mode...
Hope it will help...
geposted Sat 03 Oct 20 @ 5:05 pm
