Hi all does anyone know if there is a 'known' issue with the EQ's at the moment - I'm dropping the low full out on tracks and getting some odd sounds out - very hard to describe but its like an 'echo' or 'flanger' is on. It happens to all tracks not just one and on all decks. I've checked that all the effects are off and have still not played about with the stems. I have the latest build with all the latest updates if that makes a difference - any advice would be very gratefully received as whilst the sound is unique its starting to get a tad annoying lol Thanks all
geposted Fri 18 Sep 20 @ 12:03 am
are you sure your not adjust stems?
geposted Fri 18 Sep 20 @ 12:12 am
Sounds like you enabled stems via EQ when you started up vDJ
geposted Fri 18 Sep 20 @ 1:52 am
Thanks for the replies guys - So just to be 100% sure I hadn't inadvertently made any changes to the stems I have checked each of the decks (I'm using 4) and all of them are at zero % on everything - although even so they were not toggled 'on' in each of the decks effects drop down boxes and I am still getting the same odd sound. not sure if I can upload a 'sound clip' here or not which would make it easier to understand.
geposted Fri 18 Sep 20 @ 10:45 am
