~~~ removed ~~~
geposted Mon 21 Sep 20 @ 4:53 pm
What do you mean by not really deleted? Do you still see the track when opening the playlist again? If so it's probably a permission problem preventing you to write to the playlist. (Maybe because soundswitch is still accessing it?)
geposted Mon 21 Sep 20 @ 4:56 pm
the remove from playlist only remove from current playlist (playlist) the m3u file is only loaded in the playlist
to remove from the m3u either save playlist again with same name
or remove from m3u with the browser from playlist folder assuming showM3UAsFolder option is on)
geposted Mon 21 Sep 20 @ 4:58 pm
It was my mistake, ive analyzed the items at the wrong database.xml.
Ive deleted my topic already, but you were already on the way to answer :c)
Thank you for this powerfull support.
geposted Thu 24 Sep 20 @ 9:37 pm
