I have been trying to figure out how to record a loop while I am spinning with the stems settings applied, but the recorded sample is always the sound without the stem settings that were applied at the time of recording. By this I mean, the recorded sample sounds like the tune with no stems applied.
Is there a way to do this? While I am spinning?
Thanks
Thanks
geposted Tue 29 Sep 20 @ 5:59 pm
I've not tested myself but are you [source capture] recording loops [inside a loop] or are you [real] record start, record stop?
there's a difference
I've argued a few things around this, I've worked around some too, but everything I've scripted for live loop capture & repeat doesn't cover everything or get it right.
geposted Tue 29 Sep 20 @ 6:35 pm
I just tried recording the loop with the stems on, the voice on, and the other buttons.
the stems have been recorded (loop, voice etc.)
no problem
no problem
geposted Tue 29 Sep 20 @ 7:06 pm
there was some discussion on this a little while ago.
you can record a loop with stems applied using loop record if it's an audio file but not a video file. but.. if you want to record a video loop with stems applied then you have to record from master and then edit loop sample
https://www.virtualdj.com/forums/237367/VirtualDJ_Technical_Support/Recording_samples_with_stems_isolated__Can_it_be_done_.html
geposted Tue 29 Sep 20 @ 7:10 pm
i just tried the video mp4 i have no problem
everything works fine in mp3 and mp4 video
vdj8.5-64 b6106
vdj8.5-64 b6106
geposted Tue 29 Sep 20 @ 7:22 pm
Ah yes it does work well. Not sure why it seemed it was not working before. Operator Error, most likely.
Thanks all!
Thanks all!
geposted Tue 29 Sep 20 @ 8:08 pm
