how to set a variable to negative value ?
positive value :
"set myvar 1 " sets the var to 1
"set myvar +1 " increments the var
negative value :
"set myvar -1 " decrements the var
of course "set myvar 0 & set myvar -1" sets the var to -1
but side effects when setting from scripts
"set myvar `get_constant -1`" decrements the var
"get_constant -1 & set myvar" does not do what it seems to... stored value is 0 (result for last command run success ?)
"get_constant -1 && set myvar" decrements the var
"get_constant -1 && param_cast absolute && set myvar" finally works
"set myvar `get_constant -1 && param_cast absolute`" finally works
positive value :
negative value :
geposted Sat 03 Oct 20 @ 5:14 pm
