Topic: Jog_touch + effect
Good day DJ's
Please I want an action like, anytime I touches the jog then the cut effect also activate. Not for jog_touch action but for keyboard
geposted Tue 13 Oct 20 @ 9:47 pm
Not sure I understood what you meant...
You want the action on the jogwheel or on keyboard?
geposted Wed 14 Oct 20 @ 9:59 am
I want it in such a way that, I can activate or deactivate it at any time I want. I hope u get me? Keyboard will be best.
geposted Wed 14 Oct 20 @ 12:19 pm
many ways, one way could for example be to put a keyboard key to activate Cut (on/off)
For example set the keyboard key Z to the action : effect_active "cut"
Then at the jogwheel entry in the mapper change to : effect_active "cut" ? effect_slider "cut" 1 : jogwheel
geposted Wed 14 Oct 20 @ 12:49 pm
Please this didn't work.
What I want is, the effect cut will activate when the jog touches and deactivate when the jog has released.
Hope you get my point.
Thanks
geposted Wed 14 Oct 20 @ 8:37 pm
Still waiting
geposted Thu 15 Oct 20 @ 2:46 pm
We're all waiting too, for you to buy a license.
geposted Thu 15 Oct 20 @ 4:03 pm
+1 but our comments will get deleted again, same as last time, and the time before .......
geposted Thu 15 Oct 20 @ 5:00 pm
It's quite easy to do with a controller, but will be a bit tricky if you want this functionality on the skin Jogwheel.
So which of the 2 are you looking for ?
geposted Thu 15 Oct 20 @ 6:34 pm
Skin jogwheel Boss
geposted Thu 15 Oct 20 @ 7:13 pm
