Topic: CUE file generation when broadcasting?
dustycatControlleristMember since 2016
Hi,
Is it possible to generate a .CUE file or something like it... except instead of generating it while recording, it's created while broadcasting.
Alternatively, is is possible to create a .cue file from an Automix without recording.
Thanks!
geposted Tue 17 Nov 20 @ 6:44 am
The easiest solution it to just record while broadcasting and use the resulting .cue file.
Alternatively, you could see if you can use the .m3u files (they have comments with timestamps) or the tracklist.txt file.
geposted Tue 17 Nov 20 @ 7:21 pm
