so im new to this controller i have followed all the steps i have a pro licence but yet the virtual dj screen will not push to the prime 4 touch screen i am in need of help with this if anyone can help me i would be very greatful
geposted Tue 17 Nov 20 @ 3:25 pm
See here:
https://www.virtualdj.com/manuals/hardware/denon/prime4/setup.html
Not sure what you meant by "pushing the screens", but perhaps you didnt sent Prime in "computer mode" then?
geposted Tue 17 Nov 20 @ 3:28 pm
i have had it set up where the screen is on the prime 4 2 days ago and now it wont show on the prime 4 ive uninstalled and re installed everything including vdj
geposted Tue 17 Nov 20 @ 3:48 pm
i have even followed that setup and still nothing prime 4 works but doesnt show vdj on prime 4 touch screen
Try delete the prime 4 skin file in /documents/virtualdj/skins/ and then start VirtualDJ.
So that it auto fetches/updates the skin..
Works then?
Works then?
geposted Tue 17 Nov 20 @ 4:03 pm
I have same problem
Opdate to macOS 11 and its worked
geposted Thu 12 Aug 21 @ 6:54 am
For Denon screens on Windows, you may need to install
https://aka.ms/vs/16/release/vc_redist.x64.exe
geposted Thu 12 Aug 21 @ 8:56 pm
I had to plug mine back into the original USB port that it was plugged in to for the first time. For some reason if I plug it into any other USB port it will not push the screen to the Prime 4.
geposted Tue 05 Jul 22 @ 4:34 am
