Using VirtualDj V8.5-64 b6156 , when i click the shader/cover video options VDJ crashes.
The shader/cover list will show briefly then crash
The first time it happens it restarts and resume from where it left off, second time it just restarts.
Cpu: ryzen 2700x
video : nvidia gtx-1080ti (tried with use this gfx card on & off)
ram:16gb 3666mhz ram
hdd:512 nvme
os:win 10 build 1903
darkspr1te
Cpu: ryzen 2700x
hdd:512 nvme
darkspr1te
geposted Wed 18 Nov 20 @ 6:56 pm
Not 100% sure what you meant by shader/cover list or options?
with list, you mean the video effect list, and crash just by activating the effect?
Or do you mean opening the options for the effect?
Using River Tuner? could try disable that and see... just to test
geposted Wed 18 Nov 20 @ 7:36 pm
Bingo, Rivatuner was the issue, Solved!!!
darkspr1te
geposted Wed 18 Nov 20 @ 7:58 pm
