Hello,
I wanted to inform you that the VIEW button that when hold down for more than 1 second to open the SETTINGS view on the SC5000M screen seems to have stopped working in this version. Configuration window does not open on SC5000M. Can someone else confirm it?
Please review it and correct it if necessary in the new beta.
I also want to inform you that after the last beta BUILD 6167 (2020-11-17), the anomaly in the operation of the motorized plate of the SC5000M unit (drifting problem) seems to have been solved, although I am still testing it with the 10 minutes that it allows me to test the beta version.
And finally, is there a way to configure the display of the Denon SC5000M units, in which the bottom part only shows the waveform, without the strip with the cue, loop, slicer, sampler buttons ... ?
Thanks.
Thanks.
geposted Fri 20 Nov 20 @ 9:12 am
Use factory default mapping.
Update the Denon screen skin from VirtualDJ Extensions tab of Settings
geposted Fri 20 Nov 20 @ 9:26 am
Ok. Thanks @djdad.
It's solved. I keep testing.
geposted Fri 20 Nov 20 @ 1:45 pm
