we are going to try something, save the settings file which is in the vdj folder.
then delete the settings file, puids launch vdj and try your point cue 1
geposted Sun 22 Nov 20 @ 3:59 pm
locodog wrote :
Any chance you set the readOnly setting to true?
let me check.
geposted Sun 22 Nov 20 @ 4:06 pm
Loco. Yes. It was set to yes. I just set it to No and saved cue points and relaunched VDJ. Voila. They saved.
geposted Sun 22 Nov 20 @ 4:09 pm
I was about to try this but tryed Loco's Suggestion 1st. It seems ok now thanks.
no problem, if you had deleted the settings file made the readOnly setting would have defaulted to no. So much better it works
good mix
good mix
geposted Sun 22 Nov 20 @ 4:14 pm
Thanks again to all of you for your help. seriously you guys are the best :) VDJ FTW
geposted Sun 22 Nov 20 @ 4:16 pm
I'm sorry to have to raise this again but I'm lost. I analysed all my bpms. I used the recurse to check. 2 days later I turned on laptop and they have all disappeared ? I dont understand. I checked it the next day after I did this to now find no bpms showing. Ive checked again the read only setting is set to no.
Any input please ?
Any input please ?
geposted Wed 25 Nov 20 @ 5:40 pm
Ok. Please someone explain this to me.. I did some research and was told to go to Task manager and end the VDJ process. because an old process was hanging that being VDJ. I did that, rebooted the program and Voila. All bpms etc reappeared.
Why did I have this issue ?
geposted Wed 25 Nov 20 @ 6:19 pm
The other process already taken the database then so to speak..
So the 2nd instance dont have same full access..
But yes, seen that happen a few times, glad you got it sorted out ;-)
geposted Thu 26 Nov 20 @ 11:26 am
