New Pioneer DDJ-sb3 When playing music none of the tracks have lyrics dumbfounded.
geposted Wed 23 Dec 20 @ 1:13 am
You Must Turn On the Video and use Karaoke Tracks for that.
geposted Wed 23 Dec 20 @ 3:45 am
Im confused my old Numark played the tracks with no issues, now I have to play the
Songs in some video/ karaoke mode how do I do that ?
geposted Wed 23 Dec 20 @ 11:50 am
You need to provide more information.
What kind of tracks are they? Audio, video, karaoke?
Where are you expecting to see the lyrics?
geposted Wed 23 Dec 20 @ 3:42 pm
No these are audio tracks that are playing with no lyrics in them like they were a instrumental but they are normal tracks with the lyrics Mysteriously missing.
geposted Wed 23 Dec 20 @ 7:43 pm
Have you activated stems to remove the vocals?
geposted Wed 23 Dec 20 @ 7:52 pm
What are these audio tracks that are playing with no lyrics used for?
geposted Wed 23 Dec 20 @ 9:03 pm
If You are on Pioneer Dj DDj-SB3 Set all nobs pointing up^ on the mixer. see if that helps. If not then you have a changed setting somewhere.
geposted Wed 23 Dec 20 @ 9:08 pm
1) Select all possible EQ Modes and check, if the EQ knob with the name "Vocal" is in the middle.
2) Go to the decks and select the pads "stems", check if one of them is pressed at deck 1 or deck 2
geposted Wed 23 Dec 20 @ 9:51 pm
You mean vocals (i.e the singer).
When you said lyrics, people naturally assumed you were talking about words displayed on screen.
This is why you need to give detailed information.
geposted Wed 23 Dec 20 @ 11:39 pm
Thanks for all the help the problem was with virtual D j's new equalizer and positioning of the various knobs on the computer screen.
geposted Thu 24 Dec 20 @ 3:27 pm
