Hi,
I can't login to Beatport through the app. I have tried using the version from the Mac App Store and version directly downloaded from virtualdj.com. I can successfully log into soundcloud with no issues.
When I click login nothing happens, I have also right clicked on "Beatport" and when I click login nothing happens. I have tried deleting the app and reinstalling but the same happens each time.
macOS Big Sur 11.1
MacBook Pro M1
macOS Big Sur 11.1
MacBook Pro M1
geposted Sun 27 Dec 20 @ 3:58 pm
You could run the Rosetta (intel) version of VirtualDJ on the M1 for now for Beatport support
M1 support for Beatport might come soon ;-)
geposted Sun 27 Dec 20 @ 4:40 pm
Where do I get an older version from? The Mac App Store and download from virtualdj.com both run Apple Native.
geposted Sun 27 Dec 20 @ 9:44 pm
Right-click VirtualDJ and select 'Get Info', then check 'Run with Rosetta'
geposted Mon 28 Dec 20 @ 6:16 am
Awesome mate! Thank you!
geposted Tue 29 Dec 20 @ 11:23 am
Hi all , sorry the grab here, but is there any news regarding m1 nativ support ?
geposted Wed 31 Mar 21 @ 11:26 am
