Hi I have a DDJSB2 and I recently bought a new laptop and installed virtual dj on it but I doesn't see my controller im hitting a wall driver for controller has been install and yet nothing can any give me some direction windows 10 is the operating software
geposted Wed 13 Jan 21 @ 1:39 am
Did you install the audio driver from the Pioneer page?
VDJ does not contain drivers for the controllers, it contains mappings.
You need the Pionerr driver as well.
geposted Wed 13 Jan 21 @ 8:09 am
You probably just need to install the drivers...
See here:
https://www.virtualdj.com/manuals/hardware/pioneer/ddjsb2/installation.html
See here:
geposted Wed 13 Jan 21 @ 12:10 pm
I have the drivers installed but nothing.... I've even tried uninstalling the drivers in the hope the virtual dj would ask me to install drivers but it doesn't windows see the controller and says device is working properly im so lost
geposted Thu 14 Jan 21 @ 2:16 am
You've not mentioned the version of VDJ you're using. If it's an old version then it may not natively support the SB2. You should always run the latest VDJ version.
Does the SB2 work OK with Serato?
geposted Thu 14 Jan 21 @ 9:09 am
I'm using virtual dj home plus V8 _64 b6242 which was working fine for several years with this controller the only real change is the laptop the old one stopped working and now the software just doest see it in audio settings
geposted Thu 14 Jan 21 @ 2:10 pm
.. but works as a MIDI controller ? meaning that when you move the Pitch fader on the SB2, it also moving the one on the skin/screen ?
One suggestion... with the SB2 plugged, open the Windows Sound settings and choose the computer's built-in for Speakers and Microphone instead of the SB2 and try again.
geposted Thu 14 Jan 21 @ 3:48 pm
when i open my sound settings the SB2 is not listed but in the device manager its there and when i click on it, it shows device working properly.... but still not working the virtual dj i even tried serato and it says cant connect... this is so frustrating i will add that when the controllers is connected all lights are working and i have even changed ports and cables
geposted Thu 14 Jan 21 @ 11:49 pm
check spec. on laptop . intel processor? is yourl laptop new or used?
geposted Fri 15 Jan 21 @ 2:46 pm
i have a apc controller and cant see it on virtaul dj can you help
geposted Thu 29 Jul 21 @ 9:56 am
Hi I have a DDJ-FLX6 why I doesn't see my controller
geposted Fri 24 Sep 21 @ 11:06 am
You re probably using an old/outdated Build of VirtualDJ.
Please download the latest available from https://www.virtualdj.com/download/index.html
geposted Fri 24 Sep 21 @ 6:13 pm
Virtual dj software suddenly stoped...not working in controller
geposted Fri 30 Jun 23 @ 4:26 pm
