Hi, guys. Downloaded the latest VDJ update, but discovered Sampler no longer saves the volume levels adjusted to my specifications. However, problem began only after upgrade. Also, on sidenote, I would prefer a numerical reading on the volume levels of samples to indicate actual increases or decreases. At the moment, it is more a case of guesswork. Please, respond.
geposted Mon 25 Jan 21 @ 2:21 am
Is it a zipped bank?
These can not be changed unless unzipped first (but should produce a warning)
Else you should be able to change volume on the fly in sampler area (that is reset on start up)
Or "permanently" in the sampler editor
https://virtualdj.com/manuals/virtualdj/interface/browser/sideview/sampler.html
https://virtualdj.com/manuals/virtualdj/editors/sampleeditor.html
geposted Mon 25 Jan 21 @ 1:18 pm
All vocal and sound effect samples were installed from Virtual DJ Extensions. Before upgrade, it automatically saved volume levels to my preferences. Now, each time I reopen VDJ, I have to manually readjust volume levels, which can be really annoying. Is it a bug or something?
geposted Mon 25 Jan 21 @ 6:35 pm
Viewed the link. But something has changed definitely with latest upgrade. I could have adjusted the volume from Sampler sidelist view (as shown above) and the volume level would have been automatically saved. Not anymore.
geposted Mon 25 Jan 21 @ 6:46 pm
