So I've tried adding the new "is_using stems" to a video skin
Like:
<item class="stemspanel" visibility="is_using 'stems' 1000ms 8000ms"></item>
That part is fine - but then in my new stems panel, can I then ask which of the stems has been triggered?
Like for instance on samples it's:
action="get_sample_name 'active' & param_uppercase"
But I don't think a "get_stems_name" exists?
Like:
geposted Sun 07 Feb 21 @ 3:31 am
in fact you can only know the status of a specific stem
so that you have to test all 5 in a way to know which are trigger or isolated
but badly ... stems volume and "composite" stems can interact with every other
stem Kick, stem Bass, stem Vocal, stem Instru, stem HiHat, stem rhythm, stem, melody, stem melovocal
all 8 return a value (0.5 being the "normal" default value)
< 0 they are isolated > 0 they are powered 0 when muted
maybe some other possibilities exist
geposted Sun 07 Feb 21 @ 4:10 am
