For some reason, Tag Editor cant search for covers on google or discogs. Only show results from itunes service.
Only occur on my desktop, in my laptop works fine.
Both are connected in the same network.
geposted Sun 07 Mar 21 @ 9:51 pm
Blocked the service somehow ?
(although that would be quite odd)
Works fine my end at least.. ;-)
geposted Sun 07 Mar 21 @ 9:55 pm
I dont know how. Nothing has changed in my desktop.
Search in Chrome, Firefox or Edge works fine.
geposted Sun 07 Mar 21 @ 9:57 pm
Hmm strange. Not sure what that could be
geposted Sun 07 Mar 21 @ 10:00 pm
I'm trying to run an network monitor to see if url calling from vdj is not resolved. But its fine. The calling to discogs occur, but not showing in the Search CoverArt.
I've reset all config (include delete setting xml) but not work.
geposted Sun 07 Mar 21 @ 11:20 pm
Well, uninstall the app, reinstall and copy my setting folder backup works.
geposted Mon 08 Mar 21 @ 12:16 am
hmm .. Not sure what went wrong, but at least you got it sorted.. ;-)
geposted Mon 08 Mar 21 @ 12:34 am
The issue come back again. 😡😡😡
No changes has made in my desktop.
Never turn off the cpu because is my personal server too.
geposted Tue 09 Mar 21 @ 4:32 pm
If you open this url in browser:
https://www.google.com/search?q=bruno%20mars%20album%20cover&tbm=isch&gws_rd=ssl
do you get some google block, asking you to show you are not a robot?
Probably not it, but worth a try
geposted Tue 09 Mar 21 @ 5:23 pm
What xml file in vdj and what thus it do?
geposted Tue 09 Mar 21 @ 9:20 pm
doesnt seem related to the topic here.. that was about Google album art covers.
VirtualDJ saves settings (the software options) to XML and also the database is XML (info about your songs)
geposted Tue 09 Mar 21 @ 9:41 pm
Now works again.
I don’t understand what’s happened
Search in google on a web browser works fine.
geposted Tue 09 Mar 21 @ 10:11 pm
I find the problem.
My “data & settings” folder is a hard link to another drive, because my installation is on a small ssd.
This drive is fat32.
Then the folder of cover cache is in data & settings of VDJ.
This folder have a lot of files (more than 15000).
My suspects are: the drive is not ntfs and the amount of files on the folder is a bottleneck to the search.
I converted this drive to ntfs and the issue is gone (for now) 🙏🏻
geposted Fri 28 May 21 @ 7:49 pm
