Topic: BroadcastDirectQuality Question ?
Hi I am asking help for the best settings for Broadcasting one particular thing that is confusing me is the broadcastDirectQuality it has low,medium and high for best audio sound is it better to put on low as its less compressed then?
Also any other tips to improve Broadcast Audio better I have already set the video quality to 320kbps for the audio
Thanks
in advance
geposted Mon 15 Mar 21 @ 11:48 am
High is best quality.. .
You probably dont need 320 audio, since the value in VDJ is given is in AAC, and 192 is already very high.
You can also set custom broadcast quality in settings if you prefer.
In the syntax ResYxResX@videobitrate,audiobitrate
geposted Mon 15 Mar 21 @ 3:17 pm
