I have virtual DJ i am useing my traktor S4 works great nut can't get the microphone or headphones to work
thanks
thanks
geposted Tue 16 Mar 21 @ 8:38 am
Which version of the S4?
What do you mean "not work"?
What is your sound config?
You need to give more info.
geposted Tue 16 Mar 21 @ 9:38 am
I don't know much about the s4 but on my controller numark mixtrack pro 11 the audio settings are master on channels 1 & 2 and the headphones are on channels 3 & 4 but the microphone is wired in to the master output of the controller so i use a seperate microphone using the mic input on the computer and all the audio settings are wasapi hope this will help.
geposted Tue 16 Mar 21 @ 3:32 pm
