Want ro create a catalog for ask the dj so they audience can search through? Need a how to....
geposted Fri 19 Mar 21 @ 1:50 am
One simple way:
create your list (display karaoke only & recurse root folder or search or playlist or folder or virtual folder... )
show it in browser
select "Artist" & "Title" columns only
export browser view
show it in browser
export browser view
geposted Fri 19 Mar 21 @ 4:30 am
I don't see the export part I'm missing something.
geposted Fri 19 Mar 21 @ 5:59 am
browser options cog bottom left of toolbar
geposted Fri 19 Mar 21 @ 6:29 am
First Recurce your whole library so you will have all the files in the textfile (Csv) you are creating.
This picture is an example.
You dont need more than Artist and Songname for AskTheDj so you should delete the red colums in Exel as I show in this picture and save the file to what name you want it to have.
Then import it to AskTheDj.
geposted Fri 19 Mar 21 @ 2:09 pm
Gotcha Thank you buddy
geposted Fri 19 Mar 21 @ 7:39 pm
