MY Denon DM6000MKII is acting up and i need a list of current controllers that are compatible with Virtual DJ
geposted Wed 24 Mar 21 @ 3:16 am
fill your boots
http://www.virtualdj.com/wiki/VirtualDJ8%20Controllers.html
geposted Wed 24 Mar 21 @ 4:14 am
Can see here also:
https://www.virtualdj.com/products/hardware.html
And generally speaking can pretty much use anything with VirtualDJ ;-)
geposted Wed 24 Mar 21 @ 9:30 am
Better tell us your needs so that we can narrow it down a little for you
geposted Wed 24 Mar 21 @ 10:14 am
If he's a Denon fan, then maybe the Prime Go, 2 or 4 would suit.
geposted Wed 24 Mar 21 @ 10:36 am
I'm a big fan of the DDJ-1000 and it works almost perfectly with Virtual DJ. Much better than with Rekordbox in my opinion.
geposted Wed 24 Mar 21 @ 1:14 pm
Thanks. I am looking for a controller with at least one extra RCA line and 2 mics. Trying to keep it under $1K.
geposted Wed 24 Mar 21 @ 5:22 pm
locodog wrote :
fill your boots
Thanks,,,cant believe all of these are compatible,
Rune (dj-in-norway) wrote :
Can see here also:
Wow...thank You
geposted Wed 24 Mar 21 @ 5:23 pm
Hello. The ideal replacement for the Denon 6000 mk2 for the work of a mobile DJ is the Roland J707M controller, excellent microphone lines, good routing for connecting videographers, monitors, etc. I use this with the virtual DJ 2021, very well copes with tasks.
geposted Thu 25 Mar 21 @ 10:08 am
