Hello!
I noticed this today with VDJ and the screens on the jog wheels. It seems like the marker isn't accurate to how vinyl works. Maybe it's a bug or a miss calculation with how it's programmed? I've included a video below to show the problem.. Maybe an update can fix this..
Video Here: https://www.youtube.com/watch?v=kmio4SmZ7kM
geposted Wed 31 Mar 21 @ 12:17 pm
Does your rpm setting in vdj match whatever pioneer uses?
geposted Wed 31 Mar 21 @ 12:24 pm
Where is the RPM settings and where can I find the RPM my controller uses?
EDIT: Nah it can't be an RPM issue.. This is definitely an issue with how VDJ is coded to work. It seems like scratching is effected by the pitch/tempo slider. If I set the pitch bend percent to "WIDE" and have the slider set to -100% the sound can't be scratched. On real vinyl you can always scratch the same no matter where the pitch/tempo slider is located.
geposted Wed 31 Mar 21 @ 12:34 pm
Part 2: https://youtu.be/QNpMjDnTaII
Here it's showing the pitch/tempo slider is effecting when I scratch..
geposted Wed 31 Mar 21 @ 12:56 pm
You can find the rpm value in options.
Not sure if it's related in this case though, but still worth to check.
I don't see anything in the mapper that would make scratching depend on the pitch slider. It is actually not scratching at -100% pitch, or it's just not showing on the display?
geposted Wed 31 Mar 21 @ 1:15 pm
If you watch the videos you can understand the issue more. Messing with the RPM settings doesn't do anything.. When the tempo slider is set to -100% you can't scratch at all and when it's at +100% then it uses more of the sound when scratching. I also own Rekordbox and djay, but the issue doesn't exist there. There must be some type of programming calculation that's off or maybe they should set a boolean for when the person is scratching.
geposted Wed 31 Mar 21 @ 1:27 pm
