I'm on a trial version seeing if I like VDJ (so far I do)... however I noticed that the FX starts to act funny after using a few of them. I noticed that if I change the color FX to loop roll, use an echo combined with reverb, the color FX knob stops working. It doesn't need to be that exact step... once I restart VDJ everything works again until I do another combination of using the paddle to trigger an FX and then the color FX knob.
I also noticed that if I use too much FX, the echo seems to keep older sounds in memory instead of playing the current sound playing.
If this can get sorted out... I'll be buying a license ;)
geposted Sat 03 Apr 21 @ 6:53 am
This looks as the same bug I have with my reloop Elite controller:
https://www.virtualdj.com/forums/239488/VirtualDJ_Technical_Support/Bug_with_ColorFx_and_Reloop_Elite.html
geposted Sat 03 Apr 21 @ 10:02 am
It' s a bit different issue, the one was spotted for Elite, but what you reported for One is already fixed for next update
geposted Sat 03 Apr 21 @ 5:58 pm
sounds great.... and when can we expect this next update?
geposted Sun 04 Apr 21 @ 1:36 am
