I jus got something that I don't think I have seen before (image below)
I loaded 2 tracks and asked for vocal and beat stems
I got 6 files like expected
But only the first track's stems are named how I expected it
The second track's stems only have the stems name in them
If I then delete everything and start over using just the second track, I get even stranger stems names
It's not a general issue - so maybe something to do with the tags on the track?
geposted Mon 12 Apr 21 @ 3:28 pm
was some strange naming here also, if adding same song as previously added or same song to multiple playlists.. a bug it seems ;-)
geposted Mon 12 Apr 21 @ 4:15 pm
I also had some odd things happening with the Quick Filters.
Just as a test, I made a filter as Artist = Robbie Willliams and named the button 888.
This worked as expected. If I was in a suitable folder, clicking the button displayed all tracks by Robbie Williams. The file count seemed to be out though. It was counting one higher than the number of tracks.
After I deleted the quick filter, it seemed to be still active. Folders were showing no content (because there were no Robbie Williams tracks in the folder). Then at one point, a blank button was displayed next to the quick filter button, so I edited that and removed it, which fixed the problem.
mod not related to OP. Did you post in the wrong thread?
No I didn't post in the wrong thread. OP reported a bug with a new feature. I'm doing the same.
geposted Mon 12 Apr 21 @ 5:19 pm
Yes there are many things to improve
Icons appear only when no filter was define when opening
empty blank button when filter is removed
link to http://www.virtualdj.com/goto/filter "Sorry, the link you have used is not valid anymore."
and the most problematic:
fields names list does not match historical translation (or translation need to be move)
condition "match" translation inconsistant ( <AnyCondition> missing, translate near the same as <AllConditions>)
Example in French:
<AllConditions>Toutes les conditions</AllConditions>
<AnyCondition>Au moins une condition</AnyCondition>
<Help>Aide…</Help>
<Match>Validité : </Match>
(early translations are ugly missing or ambiguous)
Example in French:
<Help>Aide…</Help>
geposted Mon 12 Apr 21 @ 11:50 pm
