New Stems are AMAZING! BUT:
I´m crossfading the Stem "Vocal" between deck 1 and 2 and sometimes the "Vocal only" of deck 2 is to quiet. What 2 do? pushing the gain of deck 2 higher! BUT!
I made a kontroller knob like: "deck 2 gain" but when the EQ is set to "5 knob" this controller changes the "instru"-stem.
I think it has to stay possible to change the gain of a deck, even when the 5 knob-EQ-Setting is used.
Is there an option?
Thanks in advance
Is there an option?
Thanks in advance
geposted Mon 12 Apr 21 @ 10:26 pm
Anybody wants to crossfade between the vocals of deck 1 and deck 2?
The STEM-Crossfading is possible with following setting to a controller slider/knob:
param_multiply 0.5 & deck 2 stem "Vocal" & param_add 0.5 & param_invert & deck 1 stem "Vocal"
Have fun with this nice function! Greetz SVENINO
geposted Mon 12 Apr 21 @ 10:29 pm
Svenino wrote :
I´m crossfading .. "Vocal only" of deck 2 is to quiet.
You might have to gain temporarily on some tracks, if the vocals on the other song are made quiet.
And you want to "boost" it a bit to fit the other decks "instrumental"..
You could map to other knob, or switch stems to not use 5 knobs..
Or use the Stems as Audio FX or use the Vocal stem only (on Filter knob as Color FX)
geposted Mon 12 Apr 21 @ 11:22 pm
Thank You very much, Rune.
Made me a kind of "Turbo-Knob" that boosts the Gain whilst pressing:
down ? deck 2 set_gain +3 : deck 2 set_gain 0
And while the command "GAIN" does not work, it has to be "SET_GAIN"
And so I could make a Slider from -3db to +3db:
param_multiply 6 & param_add -3 & deck right set_gain
Finally the "TURBO-KNOB", shortly pressed resets the gain to 0
geposted Tue 13 Apr 21 @ 6:59 pm
And so I would like to take back the "BUT" in the first post.
The STEMS are soooo amazing. They bring so much more creativity.
I love it!!!
I love it!!!
geposted Tue 13 Apr 21 @ 7:03 pm
I use CFXmaximizer for a small gain boost
geposted Wed 14 Apr 21 @ 5:10 am
