Greetings All!
I'll admit, I have NO idea where to start with this one.
I have my FX1 & FX2 on the Prime 4 mapped to "mute_stem Vocal" and "only_stem Vocal" respectively.
I am trying to add to the script to allow only ONE instance at a time - either FX1 OR FX2, but not both. For example, a song is playing and I engage FX1 to mute the vocal, then I engage FX2 - I want it to cancel FX1 and take over, kinda how you can't use Pitch Up and Pitch Down buttons at the same time, it's one or the other. Hope that makes sense...
geposted Tue 13 Apr 21 @ 1:03 am
FX1 (Mute Vocal):
FX2 (Only Vocal):
only_stem 'vocal' on ? only_stem 'vocal' off & mute_stem 'vocal' on : mute_stem 'vocal'
FX2 (Only Vocal):
mute_stem 'vocal' on ? mute_stem 'vocal' off & only_stem 'vocal' on : only_stem 'vocal'
geposted Tue 13 Apr 21 @ 7:28 am
Thank you PhantomDeeJay - Worked PERFECTLY!
I'm loving my VDJ 2021 upgrade and new Prime 4 combo!
(Now if I could just figure out WTH is going on with the samples/pad assignment I'll be cats ass!)
geposted Tue 13 Apr 21 @ 10:47 pm
