Early Access 6404 - the quickfilter is not working with Audio & Videofiles when using for example: Bpm = 128
I have tried to use two fields with :
BPM < 128
BPM > 127
with better luck on audiofiles.
BPM < 128
BPM > 127
geposted Tue 13 Apr 21 @ 7:23 pm
there is no diff compare to filterfolder with folder scope
bpm are rarely integer
BPM <= 128 and BPM > 127 is not a common range (i got 2 only)
better try with
BPM <= 120 and BPM > 119
(you'll see 119.00 display, > being equal to >= )
you can try "group by BPM range 10 "
which activate a menu to select range
better try with
geposted Tue 13 Apr 21 @ 7:51 pm
