Forum: VirtualDJ Skins
Topic: Dim inactive deck?
Hi, new to Virtual DJ. I think the indicators which deck is "active" and receiving commands like start/stop is a bit hard to see, it's just small color indicators on the default skins. Is there an option or are there skins that make the distinction more visible?
Ideally, when a deck is active I would like to have the other deck dimmed (darker background or darker/more transparent controls) so I can immediately see which deck is going to receive the commands.
Also, is there a way to control the large waveforms? I'd like to have the "inactive" wave dimmed. That is, when you move the cross fader to the left, the top waveform should have full saturation and the bottom waveform should be desaturated or otherwise distinct from the top waveform.
Thanks!
geposted Sat 17 Apr 21 @ 11:20 am
