Hello, first of all I want to thank VDJ crew for this useful update, it's awesome.
On my tests I was able to export some tracks with some success but unfortunately the ones converted from FLAC to M4A by VDJ simply doesn't load/sound on Rekordbox's player although they are recognized in the playlist (I don't have any CDJ to test it but I assume it would be the same), mp3's loaded/played just fine.
I've even reinstalled Rekordbox with the same results.
On the other hand, XDJ-XZ can play FLAC files nativelly, can we have a switch to bypass the conversion on those situations?
geposted Mon 26 Apr 21 @ 9:08 pm
I just dropped a couple of flac files to a CDJ Export USB Playlist and loaded fine in RB (as m4a).
geposted Mon 26 Apr 21 @ 9:35 pm
Well, after read your reply I went to another computer and installed Rekordbox and everything works fine.
I'll have to investigate why only m4a files doesn't work in my main computer.
Anyway, the FLAC bypass petition still on.
Thanks for your help.
geposted Mon 26 Apr 21 @ 11:25 pm
You can change the cdjExportCompatibility setting to select that your device is compatible with flac.
geposted Tue 27 Apr 21 @ 4:53 am
Fantastic. This is great. Thanks a lot for this useful update.
geposted Wed 12 May 21 @ 2:43 am
