Topic: Clear_search - > stay on focused song
After I'm done searching in browser and clear the search bar I'd like the focus to remain on the same song that was focused on in search. Can I make a script for this?
geposted Wed 05 May 21 @ 3:51 pm
The list of found songs is dynamic and changes when you type in the search bar. not sure if that is possible.
geposted Wed 05 May 21 @ 4:00 pm
The search results are a "special" list. Once you clear your search, you return back to the previous list you were before.
Browser focus should be where you were before you start typing on the search bar.
Even if the list you're browsing contains the track that you're searching, it's not possible to switch focus on that track, because as explained, search results are a special list that not only changes dynamically, but also clears itself once you clear the search box
geposted Wed 05 May 21 @ 4:06 pm
Ok, thanks for the info :)
geposted Wed 05 May 21 @ 5:25 pm
