Hy all, I'm trying to use Daslight4 and VDJ with no success for the moment.
I'm on Win10, VDJ v8.5-64 b6418, Daslight 4 and i would like to make the lights work in time.
I've read this old post but it seems, at least to me, not to work
https://it.virtualdj.com/forums/199615/Old_versions/How-To__Output_the_BPM_from_VirtualDJ_to_other_software_(MIDI-Clock)__Resolume_.html
I've tried LoopBe1, suggested in the post, but i can't get it to work.
At the end of the post seems there is something more easy and powerful: Ableton Link.
But can I use Ableton Link with Daslight4 and VDJ ? If YES, someone can kindly post a step by step guide, (printscreen and so on) to achieve the result of making the lights work in time?
If Daslight is not the best for small show, what software you suggest (with step by step guide) ?
Thank you all in advance
Kind regards
Marco
Kind regards
Marco
geposted Fri 07 May 21 @ 6:39 pm
VirtualDJ can use Ableton Link.. available as plugin in Extensions in the software.
This will send bpm etc.
If Dashlight also supports Ableton Link, this should work fine.
Not sure if DasLight already support OS2L but was mentioned on their forums that they would add support. Perhaps it has by now. http://forum.daslight.com/viewtopic.php?t=5321
About 0S2L , see here:
https://www.virtualdj.com/wiki/TheLightingController%20with%20OS2L.html
This method use a protocol to directly communicate, called OS2L
OS2L works with a wide range of DMX software, such as SunLight, Freestyler, QLC, SweetLight, ShowXpress, QuickDMX etc
geposted Fri 07 May 21 @ 7:26 pm
Another DMX software that has its own ways, but do support 0S2L is SoundSwitch
https://support.soundswitch.com/hc/en-us/articles/115002557212-Getting-Started-with-Virtual-DJ
geposted Fri 07 May 21 @ 7:31 pm
