In the browser VDJ can show you which tracks are harmonically compatible with your current track using a checkmark icon in the key column. When a track is not naturally compatible, but can be compatible if it gets key shifted by one half tone, it shows the same checkmark, but darker.
I think the two are hard to distinguish with the alternating row colors of the browser, so i suggest to change the icon for tracks that are compatible when key-shifted. For example, using a tilde inside the circle instead of a checkmark (~).
What do you guys think?
geposted Sat 08 May 21 @ 3:03 pm
