Hi all,
Is it possible to get the default controller definition XML so that I might fix some pretty awful bugs in it which make DVJ unusable with it? I would be happy to submit it back to the community.
I'm not too keen on re-doing a bunch of work which has already been done, nor am I too excited to spend a bunch of time researching in order to duplicate the otherwise good work of the developers who wrote it. ....is there perhaps a Github repo somewhere of these things?
...or if anyone has any other Pioneer DJM controller definition files, that would also be helpful in absence of the official V10 controller definition.
Thanks in advance!
Thank you!
Thanks in advance!
Thank you!
geposted Tue 11 May 21 @ 12:54 am
Pioneer DJM-V10 is supported natively (at least in current EA b6439)
it it has bug, edit the map in settings -> controllers and save it
the edited map will be in VirtualDJ/mappers
geposted Tue 11 May 21 @ 2:20 am
Thank you. It's far more serious than that. The mapping is absolutely not ready for prime time, especially not for scenarios when playing with other DJs. Unfortunately, the controller definition itself needs to be modified.
I take it from responses and lack thereof that the community is not interested in this, which is totally fine. I do hope this gets fixed, and that perhaps you all even embrace the developers in the community.
Happy mixing!
Happy mixing!
geposted Tue 11 May 21 @ 9:14 am
It would help of course to specify what is wrong for us to be able to fix it...
geposted Tue 11 May 21 @ 9:17 am
