i just updated to VDJ 2021 and was recording some mixes. It sounds great on my headphones but after recording, I listened to the mix and the quality is very bad. I pluged in my DDJ SX controller to do the mix. What should I do?
geposted Wed 12 May 21 @ 2:47 am
Can you try to delete the 'record' line from your Audio setup and try again ?
Without this line, mics wont be recorded but want to rule out any hardware issue.
geposted Wed 12 May 21 @ 6:19 am
