1.) I´ve seen a script command to move all cuepoints in a track at once but don´t remember yet...
(e.g. if you switch from VDJ7 and must correct...)
2.) How to search in the forum for e.g. "cue" & "move"
I don´t see any & " " to use in the search window. Neither a advanced search...
geposted Fri 14 May 21 @ 6:32 pm
shift_all_cues ..
Search is not indexed like Google, so it searches what you input, without wildcards or &
But much better to use the editor itself in the software, and either write something you think it is, with automatic suggestions, or look at the categories. The one you wanted, is right there under "cues" :)
Alternatively you can see same here: https://www.virtualdj.com/wiki/VDJscript.html
And its a forum, perfectly fine to ask as well ;-) thats what the forum is for...
geposted Fri 14 May 21 @ 6:55 pm
2 use google site search, it's usually better, but "cue" & "move" would give a huge amount of hits going back a decade+
site:virtualdj.com WHATEVER TERMS
geposted Fri 14 May 21 @ 7:02 pm
great, thanks
geposted Fri 14 May 21 @ 7:53 pm
