Hello
is there a way to set the VU meters on the software and my hardware to behave like serato does. so the software's VU meters shows me pre fader level of the incoming signal before gain and my controller shows how loud the signal is after I've set the gain and before it goes out to the main output??
if you have used serato or use it then you'll know what I'm trying to explain
geposted Sun 16 May 21 @ 10:05 am
look into these script actions
get_vu_meter_peak
get_vu_meter
get_level
get_vu_meter_peak
get_vu_meter
get_level
geposted Sun 16 May 21 @ 11:37 am
Just change the "vuMeter" setting to "power"
geposted Mon 17 May 21 @ 11:10 am
Yes it's already on power
i want the VU on the software to show the peak VU and my controller to show the Power Vu if it is possible
geposted Mon 17 May 21 @ 3:14 pm
If your controller has software (MIDI) VU meters then it's not possible to have different algorithms on skin and controller
geposted Mon 17 May 21 @ 3:22 pm
ahh okay . can i a custom button then to turn off/hide the software's vu meters when im using my controller and then i can show them when im using the software without my controller?
geposted Mon 17 May 21 @ 7:11 pm
