Can someone please help me out with mapping the fx slider going up "+1" to the key "=" i already have it going down mapped to "-" and it works fine, i just cant seem to get it to go up.
geposted Tue 18 May 21 @ 2:00 am
Not really clear which fx slider you refer to ^^ there are a lot
if it's color fx
filter +1
filter -1
if it's slider 1 of effect in slot 1
effect_slider +1
effect_slider -1
if it's default slider of effect in slot 1..6 (replace n with slot #) can be 'mic' or 'sampler' as well
effect_slider n +1
effect_slider n -1
else add slider # (replace k with slider #)
effect_slider n k +1
effect_slider n k -1
if its video fx
video_fx_slider +1
video_fx_slider -1
video_fx_slider k +1
as well you say key '='
as ca ... this can be different depending on keyboard... fr/us layout due to shift
i
n any case picker in the map page can help to get the correct answer
type the key then use the picker at bottom right of list of verbs verb and use command you want
if it's color fx
filter +1
filter -1
effect_slider +1
effect_slider -1
effect_slider n +1
effect_slider n -1
if its video fx
video_fx_slider +1
video_fx_slider -1
i
geposted Tue 18 May 21 @ 2:37 am
