having an issue that it doesnt load the Denon Asio Driver
installed the new ver. 1.0.3
still the same
i've tried changing the sound settings in vdj so many times - i dont remember what it should actually be
have to use the volume knob for sound
channel slides do nothing
also headphone cue doesnt work
any ideas ?
thanks
still the same
any ideas ?
thanks
geposted Sun 23 May 21 @ 7:20 pm
any error message when you click apply in sound settings?
Perhaps the Denon sound card is already taken, often Windows will take it as it own default sound card.
If so make sure Windows is set back to PC sound card.. .
For the sound setup, you simply have to click the Denon MC 6000 button at top in sound settings.
And look here: https://www.virtualdj.com/manuals/hardware/denon/mc6000mkii/advanced.html
geposted Sun 23 May 21 @ 7:50 pm
