i was just spinning a few days ago and now i get the edit impossible to connect to server...how do i fix?
geposted Fri 04 Jun 21 @ 5:22 pm
radio broadcast somewhere then I guess you mean?
Check the url and port in your broadcast settings... if its a shoutcast or icecast server.
Not sure what type of broadcast you are trying
If you mean to VirtualDJ servers, see here:
https://www.virtualdj.com/forums/228453/VirtualDJ_Technical_Support/Can_not_connect_to_server.html
geposted Fri 04 Jun 21 @ 5:32 pm
