Help ! I want to create 2 custom buttons,
first one, that each time it is pressed it increases the value of the effect_slider 2 2 by 10%
I don't know how to script
param_add 10% and effect_slider 2 2 ( think I would use param_add don't know VJD syntax use, need some assistance)
so that 10 presses will change effect_slider 2 2 0% to effect_slider 2 2 100%
and then a second button to (or with shift) to decrease the value of effect_slider 2 2 10% each press.
so one button will increase the slider and the other will decrease it 10% each press.
thank you
thank you
geposted Sat 05 Jun 21 @ 7:29 am
effect_slider 2 2 +10%
geposted Sat 05 Jun 21 @ 7:42 am
A big thanks Locodog
geposted Sat 05 Jun 21 @ 8:13 am
