i just purchased the NS7 and cant get it to work?????
geposted Tue 08 Jun 21 @ 11:39 pm
A mk1, 2 or 3?
mk1 drivers https://www.numark.com/product/ns7
mk2 setup manual http://www.virtualdj.com/manuals/hardware/numark/ns7ii/setup.html
mk3 setup manual http://www.virtualdj.com/manuals/hardware/numark/ns7iii/setup.html
geposted Tue 08 Jun 21 @ 11:50 pm
I still use by NS7 mk1, so it can certainly still work
If you are using windows:
The drivers from Numark are a bit outdated, so sometimes it takes a few tries to get them to install on Windows 10
But once that works, then VDJ simply sits on top of the drivers, and after setting up the audio config to use the NS7, there should be no more issues
geposted Wed 09 Jun 21 @ 9:01 am
