Hello, I recently uploaded 2 plugins, a videoskin and a database filter. It has passed almost a week and they are still in pending mode? Is there something wrong with my plugins?? https://imgur.com/a/L5IN6Xh
geposted Thu 10 Jun 21 @ 12:23 pm
Will check the Greek version of "My Library", may need some tweaks like UTF encoding
About your Video skin, i am afraid it's not passing our flexible "quality control". Not much offered there and already plenty available showing Cover, Titles etc. and not sure how the songpos graphics are much useful in a Video skin
Here is what i get in full screen..
If it displays the items fine on your screens, then all good, but sharing with the community is another thing ;)
geposted Thu 10 Jun 21 @ 3:03 pm
Thanks. I actually copied the English version of My library and, i translated to greek and it works fine.
geposted Thu 10 Jun 21 @ 4:11 pm
Not sure what you used to create the Plugin sub-folders, but they seem wrong here..
Please fix and update your Plugin
geposted Thu 10 Jun 21 @ 4:12 pm
??????????????????? https://imgur.com/a/bA5F9k2 & https://imgur.com/a/AWVwNGT
geposted Thu 10 Jun 21 @ 4:15 pm
I 'll try to make it again....
geposted Thu 10 Jun 21 @ 4:17 pm
Perhaps it's the Tool you use to zip the files/folders. Try Winzip, WinRar and see if they have any UTF encoding settings
geposted Thu 10 Jun 21 @ 4:24 pm
I was using windows built-in zip maker
geposted Thu 10 Jun 21 @ 4:29 pm
If it says Unknown is Gdrive's fault. I re-downloaded and it is normal
geposted Thu 10 Jun 21 @ 4:41 pm
@djdad Does it work with this link I gave you?
geposted Fri 11 Jun 21 @ 5:40 pm
