Hi, I can record, or better to say, there is no sound on my recordings, I followed the tutorial , I actually create a file, but there is no sound , or data on it, I used the default mp3 , it always shows, waiting until sound starts or something
geposted Wed 16 Jun 21 @ 2:31 pm
Do you have an external mixer setup?
geposted Wed 16 Jun 21 @ 2:56 pm
Depends on gear and setup...
What are you using?
And do you have a "Record" entry in VirtualDJ sound settings perhaps., set to a source with no sound?
The record entry in sound settings is there to record external sound inputs (instead of VirtualDJ own internal sound). This should only be used with setups that require such.
What are you using?
geposted Wed 16 Jun 21 @ 3:40 pm
Hi there , I am not using anything external , just straight from a PC , I just downloaded Virtual DJ new, had it all on standard-setting, did not work, so I played around a bit , still does not , it constantly creates this file, which is empty , does not record anything, its frustrating
![](/img/338324/55806/VTDJK.jpg)
geposted Sun 20 Jun 21 @ 2:53 pm
wickedmix wrote :
no nothing connected yet, I am stuck in Germany and my mixer is at home :)Do you have an external mixer setup?
geposted Sun 20 Jun 21 @ 2:54 pm
can we see a picture of the audio config screen
geposted Sun 20 Jun 21 @ 3:18 pm
wickedmix wrote :
hello there thanks for answering, here are some screenshots, I also tried already to reinstallcan we see a picture of the audio config screen
![](/img/338369/66996/audio settings.jpg)
![](/img/338370/45601/Audio actually playswe but nothinmg gets recorded.jpg)
![](/img/338371/72051/AUDIO FILES SELF CREATED.jpg)
![](/img/338372/15442/Can open created audio file not with any format or player.jpg)
geposted Mon 21 Jun 21 @ 9:17 am
Why do you have a record input added? It means it would record from your gaming headset which is probably not what you want
And I don't think you have turntables connected to the same headset either, so you probably should remove the time code inputs as well
geposted Mon 21 Jun 21 @ 9:19 am
My friend, that was it :) YOU saved me :) thank you for that , much appreciated, today I will finally record!:)
geposted Tue 22 Jun 21 @ 11:02 am
